Anton_
Aug 31, 2020Tutor
RAM Upgrade, Fan replacement, UPS, RNDU4000
I want to upgrade my RAM in my RNDU4000. Comes with 1GB. What is the maximum for RNDU4000? Is it one or two modules? Ive read that the maximum is 4GB for this unit. Is that correct? 1x4GB, 2x2GB? ...
Anton_
Aug 31, 2020Tutor
Ok, what model are you using? How have you it setup for the NAS?
Sandshark
Sep 01, 2020Sensei
The RAM also needs to be 2Rx8 ("low density"), not 2Rx4 ("high density", sometimes labeled "AMD only"). Lower cost 4GB modules are going to be 2Rx4.
The UPS I have on my remote NAS is an AMD 500VA one. It's an older model no longer available, but any current one with a USB port (which, I think, they all do) should work. Even a 350VA one would probably provide several minutes for a 4-bay NAS.
- Anton_Sep 11, 2020Tutor
Ive found a replacement fan and RAM.
Noctua NF-A9 FLX and G.Skill F2-5300CL5S-4GBSQ or G.Skill F2-6400CL6S-4GBSQ
Could not get any other memory modules.. not in stock or not available anymore. Not manufactured.
As for UPS i will have to think about.- SandsharkSep 11, 2020Sensei
I've found eBay to be a good source of RAM for older NAS. You can find both used and new.
- Anton_Dec 11, 2020Tutor
Please help me find one or more RAM canditate that will work. 4Gb.
The only one ive found is that G.Skill but it isnt cheap. 130 euro.
Those old SO-DIMM DDR2 RAM are really expensive. The DDR3 and DDR4 are really inexpensive and can be found litterly everywere.
Looking for 667mhz or 800mhz one that is compatible.
Living in Sweden so must be able to ship to Sweden.
