Anton_
Aug 31, 2020Tutor
RAM Upgrade, Fan replacement, UPS, RNDU4000
I want to upgrade my RAM in my RNDU4000. Comes with 1GB. What is the maximum for RNDU4000? Is it one or two modules? Ive read that the maximum is 4GB for this unit. Is that correct? 1x4GB, 2x2GB? ...
Anton_
Sep 11, 2020Tutor
Ive found a replacement fan and RAM.
Noctua NF-A9 FLX and G.Skill F2-5300CL5S-4GBSQ or G.Skill F2-6400CL6S-4GBSQ
Could not get any other memory modules.. not in stock or not available anymore. Not manufactured.
As for UPS i will have to think about.
Sandshark
Sep 11, 2020Sensei
I've found eBay to be a good source of RAM for older NAS. You can find both used and new.
- Anton_Dec 11, 2020Tutor
Please help me find one or more RAM canditate that will work. 4Gb.
The only one ive found is that G.Skill but it isnt cheap. 130 euro.
Those old SO-DIMM DDR2 RAM are really expensive. The DDR3 and DDR4 are really inexpensive and can be found litterly everywere.
Looking for 667mhz or 800mhz one that is compatible.
Living in Sweden so must be able to ship to Sweden.- StephenBDec 11, 2020Guru - Experienced User
You might need to settle for 2 GB - more more available.
- SandsharkDec 11, 2020Sensei
That is a very high price. I find compatible A-Tech SODIMMs on eBay for around $50US.
The reason the 4GB sticks (both SODIMM and DIMM) are so much more expensive is that most users at the time PC2-5400/6200 was common were running 32-bit OSes that could only use 4BG total. And since most computers had at least two slots, only up to 2GB sticks were made in quantity. Anything you see for sale today was likely made years ago.
Most 64-bit OSes were servers, where registered and/or ECC RAM (neither of which will work on the NAS in question) are generally used, so the vast majority of sticks above 2GB won't work.
Unless you are running memory-hungry apps, you will not likely see any significant improvement of 4GB over 2GB.
- Anton_Dec 13, 2020Tutor
Thank you!
Ive searched at the same A-Tech and there are quite a lot of 2 and 4gb sticks.
Might want to try one 4Gb and also a 2Gb.
As far as i understand the CPU in this NAS support the PC-6400 (800Mhz)
Or is the 667mhz PC-5400 the only one that will work? Can you please provide me link/links to RAM that will work? Both 2 and 4gig.
1. https://www.ebay.com/itm/A-Tech-4GB-PC2-6400-Laptop-SODIMM-DDR2-800-MHz-200-Pin-Notebook-Memory-RAM-1x-4G/321872623386?epid=7023505332&hash=item4af11a771a:g:PToAAOSwatVe8n-L
2. https://www.ebay.com/itm/A-Tech-4GB-PC2-5300-Laptop-SODIMM-DDR2-667MHz-200pin-Non-ECC-Notebook-Memory-RAM/321784568707?hash=item4aebdadb83:g:9gMAAOSwWXNe8oPN
3. https://www.ebay.com/itm/2GB-PC2-5300-DDR2-667-MHz-Memory-RAM-for-ACER-ASPIRE-5720/224118028480?hash=item342e79b8c0:g:i4gAAOSwmY9fNsjg
4. https://www.ebay.com/itm/A-Tech-2GB-PC2-6400-Laptop-SODIMM-DDR2-800-MHz-200-Pin-Notebook-Memory-RAM-1x-2G/221892835552?epid=2256139894&hash=item33a9d7f8e0:g:p6kAAOSwhzpe8oM7
