Anton_
Aug 31, 2020Tutor
RAM Upgrade, Fan replacement, UPS, RNDU4000
I want to upgrade my RAM in my RNDU4000. Comes with 1GB. What is the maximum for RNDU4000? Is it one or two modules? Ive read that the maximum is 4GB for this unit. Is that correct? 1x4GB, 2x2GB? ...
Anton_
Dec 14, 2020Tutor
So, please provide me links to RAM that WILL work..
Sandshark
Dec 15, 2020Sensei
I cannot quarantee that RAM that is not fully labeled will work, but I did state that I believe what you pointed to will work.
Beyond that, I am not your shopping assistant.
- Anton_Jan 12, 2021Tutor
I will take the risk and try it.
Dont want to spend 130 euro for the G.Skill that will work.
Too expensive.
I have some new alternatives.. costs about the same as the A-tech. around 45 euro
I hope 800Mhz version will work. CPU supports it.
https://www.ebay.com/itm/4GB-2GB-DDR2-PC2-5300S-667MHz-SODIMM-200Pin-Laptop-Notebook-RAM-per-Crucial-IT/183789859704 - SandsharkJan 13, 2021Sensei
Faster memory will work, but it will work no faster in the NAS.
Crucial also does not fully label their memory as to whether they are 2Rx4 or 2Rx8, so you'll have to go to their site and see if they specify there.
- Anton_Aug 17, 2021TutorI have not found any RAM yet.. very hard to find.
Im looking for 4GB module. 667mhz
