TeknoJnky
Oct 30, 2017Hero
528x ram/memory upgrades
I am looking to upgrade the ram in my 528x, currently with the stock 4g. Has anyone upgraded theirs yet? Is there a list of compatible ram or details/specifics somewhere? also considering upgrade ...
- Oct 30, 2017
The 600 series can use a higher speed RAM than the 500 series
RN526X/RN528X: 4 memory slots (Max: 64GB), support up to DDR4-1866
RN626X/RN628X: 4 memory slots (Max: 64GB), support up to DDR4-2133We don’t support upgrading the RAM. You do so at your own risk. Be sure to run the memory test after replacing the RAM.
TeknoJnky
Oct 31, 2017Hero
for other's future reference, I found some additional info on my specific device:
hwinfo
Memory Device: #73 Location: "DIMM_A1" Bank: "NODE 1" Manufacturer: "Undefined" Serial: "00142A3C" Asset Tag: "DIMM_A1_AssetTag" Part Number: "TS512MLH72V1H" Memory Array: #71 Form Factor: 0x09 (DIMM) Type: 0x1a (Other) Type Detail: 0x0080 (Synchronous) Data Width: 72 bits Size: 4 GB Speed: 2133 MHz
dmidecode
Handle 0x0047, DMI type 16, 23 bytes Physical Memory Array Location: System Board Or Motherboard Use: System Memory Error Correction Type: Multi-bit ECC Maximum Capacity: 128 GB Error Information Handle: Not Provided Number Of Devices: 4 Handle 0x0048, DMI type 19, 31 bytes Memory Array Mapped Address Starting Address: 0x00000000000 Ending Address: 0x000FFFFFFFF Range Size: 4 GB Physical Array Handle: 0x0047 Partition Width: 1 Handle 0x0049, DMI type 17, 40 bytes Memory Device Array Handle: 0x0047 Error Information Handle: Not Provided Total Width: 72 bits Data Width: 72 bits Size: 4096 MB Form Factor: DIMM Set: None Locator: DIMM_A1 Bank Locator: NODE 1 Type: <OUT OF SPEC> Type Detail: Synchronous Speed: 2133 MHz Manufacturer: Undefined Serial Number: 00142A3C Asset Tag: DIMM_A1_AssetTag Part Number: TS512MLH72V1H Rank: 1 Configured Clock Speed: 1866 MHz Minimum voltage: Unknown Maximum voltage: Unknown Configured voltage: 0.003 V
I googled the part # TS512MLH72V1H and got https://us.transcend-info.com/Embedded/Products/No-688
which handily shows the specs and part #'s for other sizes too
Now, trying to find those in stock somewhere for a reasonable price..
TeknoJnky
Nov 14, 2017Hero
For future reference for anyone looking to upgrade their 528/628:
I ended buying this ram and it past a couple memory tests and I have been running it for a bout a week now with no apparent issues.
https://www.amazon.com/gp/product/B00KK8XNLA/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
I only bought 1 stick so far. Been monitoring with htop and while it has always pushed close to 4gig ram usage, I haven't seen it meet or exceed yet, rest is used for system cache.
And while I am still bottlenecked by cpu at times, the overall system has been much smoother and more responsive.
Anyway, so far so good on the ram upgrade.
- ScooobzNov 29, 2017Initiate
Just to add - for anyone else searching the forum.......
I used these for a 628x:
Samsung M393A2G40DB0-CPB0Q
4 x 16GB to give the full 64 GB supported (memory repurposed from a decom'd server)
Specs here from Samsung:
Memory test passed and no issues to date.
