blaQx
Nov 18, 2022Aspirant
upgraded ram on nas - what is inactive memory?
I upgraded the memory on my Readynas ultra 6 to 2gb.
When i check the istat all the memory appears there however i cant figure out what inactive memory is? and why its over 1gb? while free memory is roughly 100mb. Check my attached screenshot.
blaQx wrote:
When i check the istat all the memory appears there however i cant figure out what inactive memory is?- Wired memory — This is memory that applications or the system needs immediate access to, so it can’t be cached to disk. It will vary depending on what applications you’re using.
- Active memory — This is memory that is actively being used.
- Inactive memory — This memory is no longer being used and has been cached to disk. It’ll remain in RAM until another application needs the space.
- Free memory — This memory is not being used.
- blaQxAspirantThank you 🙂
