blaQx
Nov 18, 2022Aspirant
upgraded ram on nas - what is inactive memory?
I upgraded the memory on my Readynas ultra 6 to 2gb. When i check the istat all the memory appears there however i cant figure out what inactive memory is? and why its over 1gb? while free memory i...
- Nov 18, 2022
blaQx wrote:
When i check the istat all the memory appears there however i cant figure out what inactive memory is?- Wired memory — This is memory that applications or the system needs immediate access to, so it can’t be cached to disk. It will vary depending on what applications you’re using.
- Active memory — This is memory that is actively being used.
- Inactive memory — This memory is no longer being used and has been cached to disk. It’ll remain in RAM until another application needs the space.
- Free memory — This memory is not being used.
Nov 18, 2022Guru - Experienced User
blaQx
Thank you 🙂
