Dewdman42
Aug 26, 2025Virtuoso
Can I shelf a JBOD volume for later?
I have it in my mind to use drive bay #4 as a JBOD brtfs backup drive. Primary RAID1 will be in drive bays 1,2. I may have also an additional JBOD drive3 with intentionally non-raided data. The...
- Sep 01, 2025
Sorry for the late reply, I've been having login issues.
The warning saying it's going to destroy the volume when you intend to export, not destroy, is a programming error -- it points to the wrong warning or is a bad cut-and-paste by the programmer, as it's identical to the one when you are actually destroying a volume. But it does do an export. I reported the error long ago and was ignored.
If you forget to EXPORT the JBOD volume, you can boot with just that drive. It will show the main volume as "missing" and apps and such won't work, but your JBOD data will be accessible. That works because the OS partition is duplicated on every drive. But that does mean that any changes you make to the NAS after removal (like a password change), won't be there. At that point, you should back up all the files. Alternately, you can then EXPORT it (though any other time, exporting the only volume is a really bad idea). Once you do the export, it won't boot by itself again, but it will import to another volume. Thus, backing up the files before doing the export is the best practice, just in case something goes wrong with the export or import. If something were to happen to your main volume that prevents importation, you could simply create a new one with a single drive and do the import to it (which is also how you recover from an inadvertent export of the main volume)
I have not figured out what marks a volume as exported so you can undo it by a method other than import to another ReadyNAS or mark it is exported outside ReadyNASOS.
One thing to keep in mind with export/import is that there can be no volume or share names the same on the imported volume as on the main one importing it. (Well, there can be shares, but they'll end up invisible at anything other than SSH level.) File and folder names below share level are not subject to this limitation.
The EXPORT function is not covered in any Netgear documentation I've found. You can read about my experiments with it at Experiments-with-exporting-and-importing-a-volume-in-OS6-7-1. As best as I have been able to tell, there have been no changes made since then (since the warning error wasn't even corrected).
Now, all that said, a NAS is not really intended to be used that way and an external USB drive is a better solution. That's especially true now with the RedayNAS being EOL -- use a format on the USB drive that can be read by your computer in case the NAS dies.
Dewdman42
Aug 28, 2025Virtuoso
to be clear I wasn't meaning to repeatedly export it or remove it. I was meaning in the event that I need to factory reset the raid1 volume and restore it from the JBOD volume in drive bay4, I would need to remove the backup volume before the factory reset. But if I forget to export it first before removing it and do the factory reset...I won't be able to restore it..it will be lost in limbo stuck in the status for the system which is now factory reset.. its a point where simply forgetting to do something would render the data essentially gone and unable to restore from it. Yes as long as I never forget to do that on that fateful day...it could work...but...seems safer to just use USB...becuase can't make that mistake with USB backup drive.
Sandshark
Sep 01, 2025Sensei - Experienced User
I explained how you can export a volume by first booting it by itself. Not recommended except in the specific case of the original main volume being unusable (due to failure or whatever).
A second volume is not the way to do "backup", anyway, since a hardware failure can render both volumes unusable. True backup should be on a separate device, so using a USB drive is a much better method.
- Dewdman42Sep 01, 2025Virtuoso
yea thanks, I already marked your other reply as the solution. At this point if I continue with the readynas rolling forward I will only use USB volume for backup. I was only considering options to have all drives inside the box and don't need all 4 bays otherwise. But it's clear to me it will be safer and easier to just use an external USB drive for backing up the readynas. I also have an old ultra 2 plus I could ressurect, would kinda need to buy ram for it and upgrade to OS6 honestly, but I guess optionally; but in a pinch I could use that as a backup server and then do rsync backups that way rather then use an external USB drive. rsync can also verify, and its unknown to me right now what fvbackup is doing with local backups to an external USB drive.
I'm kind of thinking about picking up a new NAS hardware though, and running FreeBSD on it and then BOTH of my readynas would become, if anything, backup servers to that.
