ChuckMilne
May 08, 2021Initiate
Firmware 6.10.5 web interface broken in final release
My RN10200 had a 2tb drive die - so I replaced with two 4TB Seagate Iron Wolf NAS drives. There was a notice that a new version of the firmware was available 6.10.5 so I figured I should update this....
- May 09, 2021
I was eventually able to get Firefox on my laptop to get on the the NAS web interface after doing a lot of playing around clearing caches/histories, etc. So I chose the firmware update feature in the interface to go back to the 6.10.3 version. After a reboot this seem to allow access to the NAS interface from everywhere again. So I'm not sure what the advantages might be of 6.10.5 - but the problems with the web interface seem to negate any improvements that might be in the latest version. So I'd be wary of this available update and treat the latest version as being still in beta.
The 6.10.3 inteface does keep coming up and saying that a later release (6.10.4) is available and do I want to install that. But after my experience with 6.10.5 I think I'll keep replying to ignore the optional update and stick with 6.10.3 that has been stable for a long while.
Chuck.
GWB3
May 26, 2021Guide
Thanks
GWB3
May 26, 2021Guide
I found a way to stop the Admin signon cycle on my four RN102 NAs units. Why this works is not clear at all to me.
I log on to my NAS units, I see the main page and "quickly" click on Settings.
One the next page I quickly click on the arrow shown under the Check for Updates heading.
I select Beta. For reasons unknown to me this stops the cycling of the admin signon.
Once it stops the cycling of the admin signon I then click on the Install Firmware button and browse to my desktop to select the 10.6.4 firmware file I placed there.
On three of my units the above worked and on the fourth unit I had to try a number of times to get the cycling of the admin signon to stop by the same procedure described above.
In all four cases this was successful with no other modifications necessary.
Why this worked is not at all clear to me but I am glad to get these units back to a stable firmware 10.6.4.
Give it a shot and see if this works for you.
It took some time trying to click quickly but in the end it worked for me.
- StephenBMay 27, 2021Guru - Experienced User
Thx for sharing. The NAS does automatically check for updates when you log in, and changing the setting does change what it looks for.
It'd be interesting to know what setting you were using before. My own NAS are all set to "stable" and I have not seen the issue on three NAS. I'm wondering if you were using that, or "long-term support"
Looping in JohnCM_S and Marc_V as this might be useful info for the Netgear folks who are looking into this.
- GWB3May 27, 2021Guide
I normally have my setting to "Stable". The momentary change I made was simply to try to change soemthing on the screen that might interupt the signon loop. So changing that setting from stable to beta was only a temporary change that interupted the signon loop in some way.
Once I was able to interupt the signon loop and before I signed off I changed that setting back to Stable. Then did the firmware update on the right side of same page. I found firmware 6.10.4 on the Netgear site for the RN102 hardware.
- SThomas63120Jun 01, 2021Aspirant
I was also having this issue. It started doing the re-login loop a couple of days after I upgraded the firmware. I was able to stop the looping by turning off the file search function on the main page quickly before it did a re-login. After turning off the indexing I rebooted the ReadyNAS and I was able to login once and no more looping. I quickly downgrade the firmware back to 6.10.4 and it works fine now.
- hr_sokolowJul 21, 2021Aspirant
They have never done a properly functioning update yet. Every time you have to dance with a tambourine.
But your advice to click quickly on "Settings" and to select the "Beta" version helped!You don't even need to go back to version 6.10.4. And that's how it works. At last!
MANY THANKS TO YOU FROM RUSSIA.
Hooray!- StephenBJul 21, 2021Guru - Experienced User
The 6.10.5 hotfix solves this particular problem, so if your NAS can reach the internet you can safely update to 6.10.5.
