lgottli's avatar
lgottli
glitches ReadyNAS Pro 6 (rndp6000) - keeps rebooting when network plugged in
I have a ReadyNAS pro 6, it has the laatest firmware release, running RAIDiator-x86-4.2.31. A little while ago the unit started to re-boot by itself constantly. It has been running flawlessly for man...
  • Sandshark's avatar
    Sandshark
    Feb 08, 2019
    The NAS NIC and the power on/off circuit share a power source called "+5VSB", which is +5 volts Standby and has a very small load limit.  If the NIC is drawing too much power, that could glitch the power circuit.  If that's the issue, it could be the NAS motherboard, but more likely is the power supply.  The +5VSB is a common failure because it remains on even when the NAS is "off", since it has to power the on/off circuit for the button and the NIC for WoL to work.
    You can try disabling WoL (Wake on LAN) and see if that helps.  It probably won't for long, but it could give another clue.
    Do you have a "spare" ATX power supply you can connect externally to your Pro6 to see if that resolves the issue?
ProSupport for Business
