ITwannabe
Apr 16, 2020Aspirant
Memory for ReadyNasPro; rndp4000
To all I was able to upgrade the OS recently. Thank you to all. Along the way I thought memory can be updated to 2 gig. What is the max memory that can be used for ReadyNasPro; rndp4000? Than...
bedlam1
Apr 16, 2020Prodigy
I have 4GB happily installed in my Pro4
- ITwannabeApr 24, 2020Aspirant
To all
I updated the ram to 4 gig without problem. I looked at the OS (6.10.3) and have not found where the NAS tells me the memory size found. Not sure if the OS can address 4 gig, just curious.
If the OS can only address 2 gig then I can reduce the size of the memory stick. I did not have to buy memory since I have both size memory sticks (2 and 4 gig).
Thank you again.
PS...Look for post on APP usage. I see Plex media server and am wondering if I can use instead of ITunes to listen to music?
- bedlam1Apr 24, 2020Prodigy
Install Linux-Dash from the Apps page, it will show you Memory Installed, Used and Free and a whole lot more
- StephenBApr 24, 2020Guru - Experienced User
OS 6 certainly can handle more than 4 GB. My own Pro-6 is still running 4.2.31, and it has 8 GB of ram installed. So you should be using all 4 GB.
If you have ssh enabled (and there's no reason why you shouldn't), then you can confirm the memory by entering
# cat /proc/meminfo | grep -i memtotal
Or as bedlam1 suggests, install linux-dash.
You certainly can (and I do). You can run the Plex Server on either your PC and the NAS (or both). You can also use the DLNA service in the NAS (which is basic, but takes fewer resources than Plex).
