hezner
Dec 01, 2015Aspirant
ReadyNAS 100 - is it OK to mix hard drive manufacturers and models
I have a ReadyNAS 1100 that currently has four 1TB Seagate drives in it. I just had to put the last spare drive from the shelf to rebuild the volume when one drive failed so am shopping for a spare...
- Dec 01, 2015
hezner wrote:
Is there any problem with mixing drive manufacturers and/or model numbers if they are all on the compatibility list?
That works fine, so there is no problem doing that. I suggest the WD10EFRX. It looks like the newest model on the list, and the WD20EFRX has worked well in my Duo v1.
Dec 01, 2015Guru - Experienced User
hezner
Stephen,
Thanks for the quick response and for the good information.
