Cliff_MI
Nov 11, 2021Guide
ReadyNAS Management services offline
I have a ReadyNAS 3100 that is off line. I can't get into it at all. It refuses SSH. The Webpage hangs up and does not load. I have tried a OS reload, but I don't think that worked. It is run...
mdgm
Nov 11, 2021Virtuoso
If you can download the logs zip the first thing to check would be how full the 4GB root volume is. A full 4GB root volume can lead to the management service failing to start.
Then there's other things like the main services configuration file etc.
Failure to insert the time machine quota table could possibly point to a data volume issue, I guess, which would be more serious.
Cliff_MI
Nov 11, 2021Guide
Good to hear from you again.
I was able to pull the log file, But I don't know what file I am needing to look into.
Biggest issue is that I can't get into the device at all. ssh rejects connections. I did an os reload which reset the password and IP information. But I still can't get into see what might be filling the machine or what might have gotten corrupted.
Do you have any suggestions?
Thanks
- Jun 11, 2022Retired_Member
