praju
Sep 06, 2015Aspirant
management service is offline readynas
Hello Guys. .
I have got one readynas device. WHen i was trying to connect the server i am geting management service is offline .
So i am not able to do any setup here. Even i have tried to restart also.
Can anyone tell me the step by step procedure to configure the device ?
My requirement is that i have got one windows 2008 server which the hard disk space is almost full. So i wanted to add the readynas drive to the windows server.
i am using this server as a file sharing purpose. I dont have much idea about this NAS drive.
Please tell me to do the procedure from the begining.
Please help me to resolve the issue . .
Thank you
Ah that is probably it.
ReadyNAS OS 6.2.x does not support volumes > 16TB.
If you want a volume > 16TB you should run 6.4.0 beta. I would suggest doing a factory default after the upgrade.
Did you just purchase? If so, contact support.
- prajuAspirant
Yeah . . Its a new device . . But there is no support here . . I am in Saudi Arabia. . I am not able to get the online help from Netgear.
If there is no data loss, you can
(a) test the disks with vendor tools on a PC (seatools for seagate, lifeguard for western digital). Unformat the drives (for instance with windows disk manager) or zero them (with either of the vendor tools) while you are at it.
(b) insert one of drives (after testing) into the 2120, and see if that does the proper factory install. If it does, update the firmware to the current production level.
How many drives are you installing, and what model?
- Jun 10, 2022Retired_Member
