Mixster181's avatar
May 07, 2017
Management service is offline
I have updated my firmware to 6.7.1
Noticed that Plex was showing OFF
Each time I tried to switch to ON it would give an error
Decided to reboot
Now I cannot access the Admin page and RAIDar shows Management Service is Offline
Tried to download logs but this fails as well
Have tried to reinstall firmware but no change.
Any help would be appreciated.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    May 08, 2017
    This means your 4GB root volume is full. You could use the du command to find why it's full
    e.g.
    # mount --bind / /mnt
    # du -csh /mnt/*
  • StephenB's avatar
    does https://nas-ip-address/fwbroker respond? (using the real NAS ip address of course).
    • StephenB's avatar
      I would try over-installing the firmware again - might not work, but shouldn't do any harm.
  • Ok thx. Looks like plex media server is taking 2.5Gb. Will move data to HDD and create link. Let you know the results
ProSupport for Business
