Mixster181
May 07, 2017Tutor
Management service is offline
I have updated my firmware to 6.7.1 Noticed that Plex was showing OFF Each time I tried to switch to ON it would give an error Decided to reboot Now I cannot access the Admin page and RAIDar s...
- May 08, 2017
This means your 4GB root volume is full. You could use the du command to find why it's full
e.g.
# mount --bind / /mnt # du -csh /mnt/*
Mixster181
May 07, 2017Tutor
Yes it does, this is how I reinstalled firmware
- StephenBMay 07, 2017Guru - Experienced User
I would try over-installing the firmware again - might not work, but shouldn't do any harm.
- Mixster181May 07, 2017Tutor
thx, I have tried this again with no luck.........
- xiao123May 07, 2017NETGEAR Expert
Hi Mixster181,
Since your box has already been on 6.7.1, if you want to reinstall the firmware, you can do a os-reinstall from the boot menu. Please follow this guide: https://kb.netgear.com/22892/How-do-I-access-the-boot-menu-on-my-ReadyNAS-102-202-212-or-312
- Jun 10, 2022Retired_Member
