Mixster181
May 07, 2017Tutor
Management service is offline
I have updated my firmware to 6.7.1 Noticed that Plex was showing OFF Each time I tried to switch to ON it would give an error Decided to reboot Now I cannot access the Admin page and RAIDar s...
- May 08, 2017
This means your 4GB root volume is full. You could use the du command to find why it's full
e.g.
# mount --bind / /mnt # du -csh /mnt/*
Mixster181
May 09, 2017Tutor
Ok thx. Looks like plex media server is taking 2.5Gb. Will move data to HDD and create link. Let you know the results
- Jun 10, 2022Retired_Member
