Cliff_MI
Nov 11, 2021Guide
ReadyNAS Management services offline
I have a ReadyNAS 3100 that is off line. I can't get into it at all. It refuses SSH. The Webpage hangs up and does not load. I have tried a OS reload, but I don't think that worked. It is run...
mdgm
Nov 11, 2021Virtuoso
If you can download the logs zip the first thing to check would be how full the 4GB root volume is. A full 4GB root volume can lead to the management service failing to start.
Then there's other things like the main services configuration file etc.
Failure to insert the time machine quota table could possibly point to a data volume issue, I guess, which would be more serious.
Cliff_MI
Nov 11, 2021Guide
i see this error in the readynasd.log
Nov 10 18:12:07 southbackup readynasd[2963]: readynasd log started
Nov 10 18:12:08 southbackup readynasd[2963]: readynasd started. (restarted=0)
Nov 10 18:12:09 southbackup readynasd[2963]: Error rndb_import() ==> rc=3
Nov 10 18:12:09 southbackup readynasd[2963]: dba import failed
Nov 10 18:12:10 southbackup readynasd[3030]: readynasd log started
Nov 10 18:12:10 southbackup readynasd[3030]: readynasd started. (restarted=0)
Nov 10 18:12:12 southbackup readynasd[3030]: Error rndb_import() ==> rc=3
Nov 10 18:12:12 southbackup readynasd[3030]: dba import failed
Nov 10 18:12:12 southbackup readynasd[3094]: readynasd log started
Nov 10 18:12:12 southbackup readynasd[3094]: readynasd started. (restarted=0)
Nov 10 18:12:13 southbackup readynasd[3094]: Error rndb_import() ==> rc=3
Nov 10 18:12:13 southbackup readynasd[3094]: dba import failed
Nov 10 18:12:13 southbackup readynasd[3151]: readynasd log started
Nov 10 18:12:13 southbackup readynasd[3151]: readynasd started. (restarted=0)
Nov 10 18:12:14 southbackup readynasd[3151]: Error rndb_import() ==> rc=3
Nov 10 18:12:14 southbackup readynasd[3151]: dba import failed
Nov 10 18:12:14 southbackup readynasd[3208]: readynasd log started
Nov 10 18:12:14 southbackup readynasd[3208]: readynasd started. (restarted=0)
Nov 10 18:12:15 southbackup readynasd[3208]: Error rndb_import() ==> rc=3
Nov 10 18:12:15 southbackup readynasd[3208]: dba import failed
Not sure what that means.
- SandsharkNov 11, 2021Sensei
Have you received any messages regarding a full or nearly full OS partition? How full is /dev/md0 showing in the === df -h === section (near the bottom) of volume.log?
- Cliff_MINov 11, 2021Guide
I did not get any errors and it shows that the root folder is only 34% full.
Thanks for any suggestions
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 1.3G 2.4G 34% /
tmpfs 2.0G 0 2.0G 0% /dev/shm
tmpfs 2.0G 1.4M 2.0G 1% /run
tmpfs 987M 1.7M 985M 1% /run/lock
tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
/dev/md127 5.5T 789G 4.7T 15% /data
/dev/md127 5.5T 789G 4.7T 15% /home
/dev/md127 5.5T 789G 4.7T 15% /apps
=== df -i ===
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 504287 441 503846 1% /dev
/dev/md0 0 0 0 - /
tmpfs 504957 1 504956 1% /dev/shm
tmpfs 504957 581 504376 1% /run
tmpfs 504957 69 504888 1% /run/lock
tmpfs 504957 15 504942 1% /sys/fs/cgroup
/dev/md127 0 0 0 - /data
/dev/md127 0 0 0 - /home
/dev/md127 0 0 0 - /apps
- Jun 11, 2022Retired_Member
