jabbott
Aug 27, 2015Aspirant
ReadyNAS NV+ v2: Adding a new disk issue
Have three WD Red 3TB drives running XRAID2 (redundant). Provides 5.4TB of space. Added a 4th 3TB WD Red, but not adding to the overall space. Checking the status, the log reports new disk detec...
JennC
Aug 28, 2015NETGEAR Employee Retired
Hello jabbott,
If you have enabled email alerts maybe you will also be able to get more details about the expansion. See article:
http://kb.netgear.com/app/answers/detail/a_id/20981/related/1
Another option is to backup all the files then factory reset to get fresh install with all the 4 disks.
You may also try contacting support center at 1-888-NETGEAR (1-888-638-4327) where they will get an L3 remote in, this however requires a per incident support contract.
CholoUniverse
Oct 14, 2015Aspirant
Have 3x WD Red 3TB
Added 1x WD Red 4TB
Volume expansion seems to have failed: Wed Oct 14 07:42:25 PDT 2015
Then had a power outage tonight: Thu Oct 15 00:42:33 PDT 2015
What would cause the failure? It was not switched off or interrupted... ? Is there any more information I can get from log files?
Thu Oct 15 00:45:07 PDT 2015
System is up.
Incompleted file system expansion detected. Resuming...
Volume expansion failed
Mon Oct 12 16:40:53 PDT 2015
Volume expansion started. Do not interrupt the system during this time. When finished, email notification will be sent to the alert contact list.
Mon Oct 12 16:40:41 PDT 2015
New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 1]
Sat May 23 16:18:57 PDT 2015
System is up.
- JennCOct 14, 2015NETGEAR Employee Retired
Hello CholoUniverse,
Welcome to the community!
What's the model number, RAID level and current firmware version?
