eton
May 05, 2023Luminary
ReadyNAS OS 6.10.9 now available – With almost no info
ReadyNAS OS 6.10.9 now available! https://kb.netgear.com/000065653/ReadyNAS-OS-Software-Version-6-10-9 But there is almost no release information. What is new? There is no option to filter ...
Jan 17, 2024Guru - Experienced User
GGITech wrote:
Has anyone else had any issues with apps not installing?
Any input is appreciated, if this needs its own thread, let me know and I will start one.
See this thread:
The issue is that Debian 8 (the OS used by your ReadyNAS) is no longer supported, and has been archived by the Debian community. There are some changes you need to make to the NAS to tell it to access the archives.
GGITech
Jan 17, 2024Apprentice
Specifically #37 in that post it seems...I just ran across that.
Yeah I get 8 has been deprecated, but with the known internal dependence, I never thought they would depend on external sources for the custom rolled version....Figures, as that is more bad planning on NG's part.
I appreciate the point to that...I will start digging.
- StephenBJan 17, 2024Guru - Experienced User
Actually I think using the official repositories whenever you can is the right strategy.
That said, IMO Netgear should have done a software release (at least a hot fix) to change the apt config. They also should have done a release to fully remove ReadyCloud from the NAS. Hopefully they will eventually get around to do that.
