givememynamebak
Jun 15, 2017Luminary
ReadyNAS Pro 6 on OS 6.7.4 - Plex will no longer start
 Hi all, - just tried updating Plex to the latest from plex.tv     1.5.6.3790-4613ce077  May 9, 2017     Using Pro6 on OS6 6.7.4 and Plex no longer starts.  I see nothing for plex in /etc/init.d (not ...
- Jun 16, 2017
Checked all the logs with:
journalctl
Seemed to be an abnormally high amount of locale errors so I did:
journalctl | grep locale
Jun 10 16:43:18 ReadyNAS1 fv-app-install[26198]: Installing [/tmp/oracle-java8_8.0.131_all.deb](56%) Installing locales
Jun 10 16:43:18 ReadyNAS1 fv-app-install[26198]: Installing [/tmp/oracle-java8_8.0.131_all.deb](58%) Preparing locales
Jun 10 16:43:40 ReadyNAS1 fv-app-install[26198]: Installing [/tmp/oracle-java8_8.0.131_all.deb](60%) Unpacking locales
Jun 10 16:43:40 ReadyNAS1 fv-app-install[26198]: Installing [/tmp/oracle-java8_8.0.131_all.deb](62%) Preparing to configure locales
Jun 10 16:43:43 ReadyNAS1 fv-app-install[26198]: Installing [/tmp/oracle-java8_8.0.131_all.deb](71%) Configuring locales
Jun 10 16:43:44 ReadyNAS1 fv-app-install[26198]: Installing [/tmp/oracle-java8_8.0.131_all.deb](73%) Configuring locales
Jun 10 16:43:44 ReadyNAS1 fv-app-install[26198]: Installing [/tmp/oracle-java8_8.0.131_all.deb](75%) Installed locales
Jun 10 17:12:31 ReadyNAS1 readynasd[3697]: Failed to set locale. Fix your system.
Noticed the problem started when I installed Java 8. Plex errors also showed here as (bolded below):
Jun 14 20:12:44 ReadyNAS1 readynasd[3697]: Failed to set locale. Fix your system.
Jun 14 20:22:19 ReadyNAS1 sh[24722]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:22:24 ReadyNAS1 sh[24737]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:22:30 ReadyNAS1 sh[24757]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:22:53 ReadyNAS1 sh[24821]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:22:58 ReadyNAS1 sh[24837]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:23:04 ReadyNAS1 sh[24861]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:23:08 ReadyNAS1 sh[24885]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:23:13 ReadyNAS1 sh[24910]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:23:18 ReadyNAS1 sh[24939]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:26:19 ReadyNAS1 sh[26254]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:26:24 ReadyNAS1 sh[26276]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:26:29 ReadyNAS1 sh[26295]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:26:55 ReadyNAS1 sh[26356]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:27:01 ReadyNAS1 sh[26380]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:27:06 ReadyNAS1 sh[26393]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:31:16 ReadyNAS1 minidlnad[2860]: minidlna.c:458: warn: Unset locale
Jun 14 20:31:19 ReadyNAS1 sh[3056]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:31:24 ReadyNAS1 sh[4039]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:31:30 ReadyNAS1 sh[4185]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:31:35 ReadyNAS1 sh[4205]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:31:40 ReadyNAS1 sh[4247]: what(): locale::facet::_S_create_c_locale name not valid
Jun 14 20:31:44 ReadyNAS1 readynasd[3324]: Failed to set locale. Fix your system.
So I ran:
dpkg --list
dpkg --remove plexmediaserver-ros6-binaries
cat /etc/locale.conf
cat: /etc/locale.conf: No such file or directory
cat /etc/locale.gen
touch /etc/locale.conf
vi /etc/locale.conf pasted in:
en_US.UTF-8 UTF-8
locale
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
sudo dpkg-reconfigure locales (typed 146 enter)
1. None 2. C.UTF-8 3. en_US.UTF-8
Chose: 3 (enter)
Generating locales (this might take a while)...
en_US.UTF-8... done
Generation complete.
Re-installed Plex in frontview, installed OK
Flipped the switch to Enable or Turn on Plex... toggling modal spinner came up (which it wasn't before)
Plex stayed enabled!!!! Problem solved. Plex now works and seemed to be due to the locale issues since I installed Java 8.
givememynamebak
Jun 16, 2017Luminary
root@ReadyNAS1:~# export LD_LIBRARY_PATH="/apps/plexmediaserver/Binaries:$LD_LIBRARY_PATH"
root@ReadyNAS1:~# echo $LD_LIBRARY_PATH
root@ReadyNAS1:~# /bin/sh -c '/apps/plexmediaserver/Binaries/Plex\ Media\ Server'
terminate called after throwing an instance of 'std::runtime_error'
Aborted (core dumped)
root@ReadyNAS1:~# service plexmediaserver start
Failed to start plexmediaserver.service: Unit plexmediaserver.service not found.
Now I am stuck - again.
givememynamebak
journalctl
So I ran:
dpkg --list
cat /etc/locale.gen
en_US.UTF-8 UTF-8
locale
Chose: 3 (enter)
en_US.UTF-8... done
- mdgm-ntgrJun 16, 2017NETGEAR Employee Retired
Thanks for sharing what resolved your problem.
