Nitupsar
Jul 29, 2015Aspirant
Readynas Remote configuration problem
I have an Ultra 4 and have installed Readynas Remote. When I get to the part in the setup where it says "Select remote users to give share access" I fill in my user name and click to apply the settin...
OOM-9
Jul 31, 2015NETGEAR Expert
ReadyCLOUD is a facelift with some newer features added. When there are some updates to ReadyNAS Remote there might be some images/names that are labeled incorrectly.
Can you try registering a different user with remote.readynas.com? (Then inviting the user through the add-on and then sign into the ReadyNAS Remote app.)
You mentioned that you deleted and re-created the user; I want to make sure it is not related to the account.
Nitupsar
Jul 31, 2015Aspirant
I will do that, but duty calls and I will keep you informed of any progress..... :)
