mrmilo
Aug 16, 2020Tutor
ReadyNAS RNDU6000 memory upgrade - won't boot
I bought the ReadNAS Ultra 6 with 3x3TB disk in 2011. Upgraded to OS6 long time ago even though it was not supported. Been running fine since! Few years ago I dropped using "apps" in favor of docker ...
Sandshark
Aug 17, 2020Sensei
The 4GB limit is expected, but working with 3 and not 4 isn't. Maybe it is a BIOS issue. The BIOS update package contains RN_Ultra6_061010.ROM. bios_ver.log from the downloaded logs zip from my Ultra6 has the same 6/10/10 date, so you can check that and see if yours is different.
FYI, the fact that the NAS will boot with a single stick in either slot is usually a sign that it's not dual-channel RAM.
mrmilo
Aug 17, 2020Tutor
Bios date: 05/26/2010
I have never done a bios upgrade on my machine. Did some searching the forum and found a download link for BIOS_Update_Package_0.5-x86.bin but am uncertain it is ok to try.
- SandsharkAug 18, 2020Sensei
That's the right package, but it won't work with OS6. But before you do anything else, what version does your bios_version.log have in it? You may not need to update.
If you do need to update, there are instructions elsewhere in the forum (I don't have a link) about how to extract and install the BIOS under OS6, but the easiest way for most is to use a spare drive in your NAS instead of the normnal volume drives and revert back to OS4.2.x, then install the BIOS update add-on, then revert back to OS6 before re-inserting your normal drives.
- mrmiloAug 18, 2020Tutor
/sys/class/dmi/id/bios_date
05/26/2010
/sys/class/dmi/id/bios_version
080016Is this instruction still correct?
Definately an older version. I can't say if the update will fix the issue or not, but it's always best to have the latest if you can.
So I just followed the instructions I found. Little change for Ultra6.
This are the commands I succesfully used (for reference):
# install tools apt-get update apt-get install dmidecode flashrom apt-get install libc6-i386 # download bios package cd /tmp/ wget http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin # unpack bios package dd if=BIOS_Update_Package_0.5-x86.bin bs=16k count=1 dd if=BIOS_Update_Package_0.5-x86.bin bs=16k skip=1 | md5sum - dd if=BIOS_Update_Package_0.5-x86.bin bs=16k skip=1 | tar -xv # this unpacks following files in /tmp # install.sh # remove.sh # addons.conf # files.tgz # now unpack files.tgz tar -xvf files.tgz # this unpacks following files # ./opt/biosflash/flashrom # ./opt/biosflash/RN_3200_062410.ROM # ./opt/biosflash/RN_Ultra6_061010.ROM # ./opt/biosflash/RN_NV6_072610.ROM # ./opt/biosflash/RN_Ultra4_082311.ROM # ./opt/biosflash/RN_Ultra2_110211.ROM # ./usr/sbin/dmidecode # it actually unpacks a flashrom utility and dmicode... # using install.sh as reference for the correct -c (chip) for my Ultra6, I tried: flashrom --programmer internal -c W25Q80 -w /tmp/opt/biosflash/RN_Ultra6_061010.ROM # got an error: Error: Unknown chip 'W25Q80' specified. # now tried again with the flashrom that came with the package /tmp/opt/biosflash/flashrom --programmer internal -c W25Q80 -w /tmp/opt/biosflash/RN_Ultra6_061010.ROM # within seconds: Verifying flash... VERIFIED.
Checked the bios_ver.log log:
:::::::::::::: /sys/class/dmi/id/bios_date :::::::::::::: 06/10/2010 :::::::::::::: /sys/class/dmi/id/bios_version :::::::::::::: 080016
So all went well!
Sadly 4GB still not recognised. So still running on 3GB.
- mdgmAug 20, 2020Virtuoso
You possibly might have had to user lower case for the chip name. I think with a few models there might be some systems that used a different chip. Can't remember whether the Ultra 4 was one of those.
- mrmiloAug 20, 2020Tutor
Hmm, sounds plausable but seeing that the update was already succesfull with the packaged tool i'm not gonna test that out :) Not going to touch that ever again!
- mdgmAug 21, 2020Virtuoso
Indeed. BIOS updates are not without risk. If for example the power failed during a BIOS update a device could be bricked.
Was just pointing out in case others came across this thread later.
