mrmilo
Aug 16, 2020Tutor
ReadyNAS RNDU6000 memory upgrade - won't boot
I bought the ReadNAS Ultra 6 with 3x3TB disk in 2011. Upgraded to OS6 long time ago even though it was not supported. Been running fine since! Few years ago I dropped using "apps" in favor of docker ...
Sandshark
Aug 18, 2020Sensei
That's the right package, but it won't work with OS6. But before you do anything else, what version does your bios_version.log have in it? You may not need to update.
If you do need to update, there are instructions elsewhere in the forum (I don't have a link) about how to extract and install the BIOS under OS6, but the easiest way for most is to use a spare drive in your NAS instead of the normnal volume drives and revert back to OS4.2.x, then install the BIOS update add-on, then revert back to OS6 before re-inserting your normal drives.
mrmilo
Aug 18, 2020Tutor
/sys/class/dmi/id/bios_date
05/26/2010
/sys/class/dmi/id/bios_version
080016
Is this instruction still correct?
- SandsharkAug 18, 2020Sensei
Definately an older version. I can't say if the update will fix the issue or not, but it's always best to have the latest if you can.
- mrmiloAug 18, 2020Tutor
So I just followed the instructions I found. Little change for Ultra6.
This are the commands I succesfully used (for reference):
# install tools apt-get update apt-get install dmidecode flashrom apt-get install libc6-i386 # download bios package cd /tmp/ wget http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin # unpack bios package dd if=BIOS_Update_Package_0.5-x86.bin bs=16k count=1 dd if=BIOS_Update_Package_0.5-x86.bin bs=16k skip=1 | md5sum - dd if=BIOS_Update_Package_0.5-x86.bin bs=16k skip=1 | tar -xv # this unpacks following files in /tmp # install.sh # remove.sh # addons.conf # files.tgz # now unpack files.tgz tar -xvf files.tgz # this unpacks following files # ./opt/biosflash/flashrom # ./opt/biosflash/RN_3200_062410.ROM # ./opt/biosflash/RN_Ultra6_061010.ROM # ./opt/biosflash/RN_NV6_072610.ROM # ./opt/biosflash/RN_Ultra4_082311.ROM # ./opt/biosflash/RN_Ultra2_110211.ROM # ./usr/sbin/dmidecode # it actually unpacks a flashrom utility and dmicode... # using install.sh as reference for the correct -c (chip) for my Ultra6, I tried: flashrom --programmer internal -c W25Q80 -w /tmp/opt/biosflash/RN_Ultra6_061010.ROM # got an error: Error: Unknown chip 'W25Q80' specified. # now tried again with the flashrom that came with the package /tmp/opt/biosflash/flashrom --programmer internal -c W25Q80 -w /tmp/opt/biosflash/RN_Ultra6_061010.ROM # within seconds: Verifying flash... VERIFIED.
Checked the bios_ver.log log:
:::::::::::::: /sys/class/dmi/id/bios_date :::::::::::::: 06/10/2010 :::::::::::::: /sys/class/dmi/id/bios_version :::::::::::::: 080016
So all went well!
Sadly 4GB still not recognised. So still running on 3GB.
- mdgmAug 20, 2020Virtuoso
You possibly might have had to user lower case for the chip name. I think with a few models there might be some systems that used a different chip. Can't remember whether the Ultra 4 was one of those.
- mrmiloAug 20, 2020Tutor
Hmm, sounds plausable but seeing that the update was already succesfull with the packaged tool i'm not gonna test that out :) Not going to touch that ever again!
- mdgmAug 21, 2020Virtuoso
Indeed. BIOS updates are not without risk. If for example the power failed during a BIOS update a device could be bricked.
Was just pointing out in case others came across this thread later.
