steveoelliott's avatar
Jun 22, 2019
Replace / Hot Swap Disk - Device changed from SDB to SDE - Normal?
Hi Folks,   I have a 526X with four drives in a RAID 6 array and due to some bad sectors on one of the drives I replaced it.   It is currently syncing to the new disk but I notice that the device...
  • StephenB's avatar
    Jun 22, 2019
    steveoelliott wrote:
    I'm assuming this is to be expected even though the replacement disk went into the same bay (2).
    I just want to be sure this change of device name for the new drive won't cause any issues after reboot. I'm guesssing when rebooted the drive may get back it's sdb name.
    This is normal (I saw the same thing when I replaced a disk a few weeks ago).  It will go back to sdb when you reboot.
ProSupport for Business
