Ludde
Sep 11, 2018Aspirant
Reset switch defect, permanent boot mode
Hello *,
yesterday the nas system has to restart and afterwards the system stuck in Boot mode and only normal Boot could be chosen. But it could not be executed. Also the Firmware upgrade with ...
Marc_V
Sep 12, 2018NETGEAR Employee Retired
Hi @Ludde
You would most likely have to buy a new NAS if it does not have any warranty anymore, I'll try to check if I can provide that but I cannot guarantee.
I inquired this issue and you can take off the reset switch if it really is always on the pressed state. If the switch is working fine, a Pull-up Resistor R64 might be missing or defective.
Hope we have helped!
Regards
Ludde
Sep 13, 2018Aspirant
Thank you for the information. I
think we found the defect, but it was not the R64.
The R185 and the C154 are before the Reset Switch and connected. At R185 there were 3.3V but after the Resistor there were 0V and the resistor seems to be ok (so there was a Voltage drop of 3.3V over this resistor). The C154 has connection to Ground on both sides, so we removed this C. Nothing changed so the defect must be at the input Pin of the µC. With this defect i think i have no chance to repair it.
Thank you for your help.
