tytou
Aug 26, 2015Aspirant
RN 102 RAID 1 reconstruction takes ages with NO DATA
I've a readynas RN102 with 2 3TB hdd in it, configured in RAID 1. I have NO (in fact only very few small files) stored on it (max less than 10MB). When I test hot swap to reconstruct the RAID from o...
JennC
Aug 26, 2015NETGEAR Employee Retired
Hello tytou,
You only need RAID resync if there is a drive failure and that you have to replace it. Both file system check and RAID resync are a bit slow and read entire partition that can take a while, these things slow down more too when you use weaker processer like the ReadyNAS 100 series that has 512mb memory.
Here's an article that will help about expansion in case you need it in the future: http://kb.netgear.com/app/answers/detail/a_id/23133/related/1
tytou
Aug 27, 2015Aspirant
Many thanks for you so promtpt answers.
Kindest regards to the community.
Tytou
