Hawk321
Oct 12, 2021Apprentice
RN 104 very slow - 15 MBit/s
Hi, my read and write speed on the RN104 is very slow, around 15 Mbit/s. Well the hdds are encrypted which will lead to a high CPU usage but neverthless it should be faster. https://www.downl...
Oct 12, 2021Guru - Experienced User
Hawk321 wrote:
I have Gigabit ethernet in my apartment and that’s the speed the copy manager from Win10 shows. Sometimes it even drops below 10 MBit/s
So the win10 system is not using wifi?
I've seen some posts here that say using disk encryption in the RN104 will cut the throughput in half, but it looks like you are fetting less than that. What disks are you using?
Hawk321
No, Iam using GB ethernet with a smart-managed switch from netgear.
I use Western Digital 8 TB disks chucked from WD MyBooks, should be relabeled WD reds.
WD80EDAZ
WD80EZAZ
https://www.reddit.com/r/DataHoarder/comments/7fx0i0/wd_easystore_8tb_compendium/
MTU is 1500 on the NAS and the WIN 10 PC.
