a_carneiro
Feb 05, 2019Tutor
RR2312 noise levels
Hi guys Thinking of buying a ReadyNAS 2312 when it becomes available in Europe. This would be in my rack in the garage. Can anyone who has one tell me how noisy it is? I worry that it’ll have a ton...
- Feb 05, 2019
a_carneiro wrote:
Can anyone who has one tell me how noisy it is? I worry that it’ll have a ton of VERY LOUD fans to be able to dissipate the heat from 12 HDDs.Per the datasheet it has five 40mm fans. The noise spec is < 28 dba, which is surprisingly quiet. Hopefully someone from Netgear ( BretD ?) can confirm that spec.
https://www.netgear.com/images/datasheet/storage/RR2304_RR2312_RN3138_DS.pdf
kevinfor2014
Feb 08, 2019Guide
My concern with the RR2312 - it may NOT fit into your Server Rack... it's 909mm in depth -vs- 707mm for the RR3312/4312X models.. the other is the 4x1GB ports - why not just have 2x10G avail as an upgrade.. especially if thinking with an all SSD Solution
- a_carneiroFeb 08, 2019Tutor
My rack is a 1000mm depth, so should be fine.
Does the RRR2312 come with rails? Seems like a bit of a pain having to take it all apart very time you want to fiddle with the HDDs...
