ramymounir
Mar 02, 2017Aspirant
Strongest Processor to transcode 4K for plex
What is the strongest processor compatble with my Ready nas pro 615 if i need to transcode 4k mkv files using plex? i appreciate if you could let me know if i need to buy other things for that p...
ramymounir
Mar 03, 2017Aspirant
is this my best replacement option? i wnted to know the best possible processor to replace the orignal one
I highly doubt that processor is the best, but i am not sre. i am looking to transcode 4K movies..
rjwerth
Mar 03, 2017Luminary
"The Best" is relative. If you want "The Best" CPU that won't melt your Readynas and is a drop-in replacement, I believe that is it. If you want "The Best" CPU that will do the most streams, be prepared to do some serious modifications.
- ramymounirMar 03, 2017Aspirant
THanks man for the reply, finally an answer, ok i am willing to do some serious modifications, would you reommend what equipment i need for this upgrade?
- rjwerthMar 03, 2017Luminary
My recommendation is to follow my lead and use an external box for any processor that excedes the 45W envelope that box was designed for. There is very little space in there for proper cooling of a higher thermal CPU. I love a project just as much as the next guy, but after looking at the other thread, I felt a separate box for DVR and heavy transcoding was the answer for me.
Sorry!
- StephenBMar 06, 2017Guru - Experienced User
Also an external box offers the possibility of GPU-accelerated transcoding.
Separating storage from applications is more expensive in the short run, but it does give you more options in the future as technology changes.
FWIW, the 62x platform appears to be capable of transcoding one 4K stream in real time. My 526x wasn't quite up to that, the video stalled. It does handle 1080p transcoding with no problem.
