dtarin
Sep 20, 2023Luminary
Updating OS to something modern
So I have an old ReadyNAS NVX and a soon to be decommissioned ReadyNAS516. They're both going to turn into backup systems for a new NAS that just arrived, but am wondering.. the hardware on the 516...
Sandshark
Sep 22, 2023Sensei
The NVX, being the first Intel based ReadyNAS and designed by Infrant prior to the Netgear purchase, may not be as solidly locked down. It may use a more generic BIOS than later models. I've never tried to access it's bios (though I have two in storage). But the fact that the NVX has a 32-bit processor is going to be a bigger hurdle. TrueNAS has been 64-bit only for a number of years, as have most potential alternatives.
Given the state of Netgear support for the ReadyNAS, the ability to go back to the original OS shouldn't be much of a driver today. So, IMHO, the best solution for units that are "locked down" is to do exactly as Netgear does -- put a boot loader and small OS in flash (or use UBoot for ARM systems) that chain-loads the real OS. Of course, you wouldn't need (or likely even want) to have an image of the "real" OS in flash like Netgear does since it would likely get too big.
I would love to see a group start a project for a ReadyNASOS replacement. Not being much of a programmer or even an expert on the inner workings of Linux, my contribution could be that I have a lot of machines on which to test (unless I sell them first). IMHO, such a project should try to come as close to "for dummies" as possible for the actual conversion and not require a display. For example, use the Netgear USB recovery system to write the flash and put into that flash options to boot normally from the drives (which would be the default) or to copy an OS from a USB drive (which might be on the same USB as the recovery system or on a separate one) to the drives.
In his farewell, WhoCares_ mentioned the possibility of such a project, and I think he'd be a great one to lead it. Unfortunately, he seems to have simply given up on the ReadyNAS.
WhoCares_
Sep 22, 2023Mentor
- SandsharkSep 22, 2023Sensei
Hey, WhoCares_ , thanks for that, and good to see you're still around. It's not yet "for dummies" with no GUI, but it looks like a great start. Personally, I'd prefer a Debian (or at least Ubuntu) based system for greater familiarity and commonality with ReadyNASOS, but beggars can't be choosers. The fact that this preserves the volume is really nice, and not even something I'd expect (mostly because I'd recommend a larger OS partition).
- WhoCares_Sep 22, 2023Mentor
I never left. But for the last couple of years my account was blocked because of some weid IP restriction. Today I thought I could check again and lo and behold โ I was able to login again for the first time in 5 or 6 years ๐
Iยดm totally aware of that. Quite frankly, it was born from a "scratch your own itch" approach. I don't really need the UI but I wanted to keep the data while at the same being able to use newer tools and apps. Also:
Semantics aside (Ubuntu is based on Debian, therefor it should read "Ubuntu or at least Debian" ๐) I would agree and that was the first line of approach I used. However, the really braindead partitioner used in both, Debian and Ubuntu, prevented me from doing an in-place upgrade. With Alpine however it was really easy to keep the original partitioning and even have the ReadyNAS boot as it alwaxs does: from the internal USB memory.
Since the original Software refused to run on a system I force-upgraded to Debian 10 and since I don't think that NTGR will release the software to OpenSource I decided to ditch it completely and maybe write a new web interface if I felt the need and got the time. Using Golang one could bulld really nice integrated management apps that won't require a web server (just. look at Gitea or EVCC for examples).
This would then allow for easier integration of other apps using a more modern web server than Apache (think Nginx or Caddy) that isn't also tasked with delivering the management app. So you'd have separation of concerns which makes it easier to secure apps you maybe want to open to the internet.
I also looked at OpenMediaVault but found that it takes a totally different view on shares than th ReadyNAS. So I stopped there since the effort for translating between the ReadyNAS and the OMV approach would have been too much of a hassle.
Lastly, Alpine has a very easy way of bundling apps. So if anyone would be interested in really building apps on top of the converted system they could do so more easily than when using the Debian eco system.
That's why I decided to leave the original OS partiton as is and put the Alpine OS on the data partiton. If the conversion fails you should be able to restore the original ReadyNAS OS using the USB recovery method. I know that this also means losing 4GB of possible storage space, but then: who cares? ๐-Stefan
- StephenBSep 22, 2023Guru - Experienced User
WhoCares_ wrote:
You may want to check this: https://github.com/RustyDust/readynas-alpine
Cool.
I'm thinking that backup jobs, power schedule, and maintenance schedules are also lost, and of course X-RAID expansion.
Not sure if you are planning an Arm version too, but maybe add in x86 to the prerequisites for now.
Might also be good to note what happens if the user does an OS reinstall or a factory default from the boot menu after doing this conversion.
Correct on all accounts. That's mostly because for all of those except the x-RAID expansion I use Jenkins anyway. That said, most of these festures should be fairly easy to implement. I already noticed that NTGR seems to have ditched the "real" expansion, but create new raid devices instead that are then linked to the existing BTRFS volume. No magic anymore, can be done with the standard BTRFS tools.
Sure do, just didn't have the time to tinker with the Alpine u-boot installer. Help is welcome, though ๐
Write an issue. Or better yet, send a PR ๐
I'm not sure right now whether those options will still exist after the conversion. So I guess what's needed here is a more detailed description of how to get back to the original state. Thanks, I'll see what I can do.
-Stefan
