ndpm
Aug 01, 2017Aspirant
Vulnerabilities on Ready NAS 204
We did a scan to our network and found severals vulnerabilities in our NAS 204. I look online but was not able to find anything. here is the list: 1: SSL Medium Strength Cipher Suites Supp...
kohdee
Aug 10, 2017NETGEAR Expert
Things that help NETGEAR better diagnose these issues are also knowing which software you used to generate this report, and a copy of the report.... What you've provided here is not really explicit to any specifically known vulnerabilitiy. CVE numbers help here.
On your apache2 problems, if your scanner only checks version, then you cannot trust that. We do lots of cherrypicking from newer versions and put fixes in seemingly older versions. So likely, these are not realistic. We also do this in kernel and other things.
You could eliminate 4 of those by using HTTP instead of HTTPS :P
ndpm
Aug 10, 2017Aspirant
Nobody from Netgear try to contact me to get the report.
The scans are done with Tenable IO.
