Superdan186
Feb 22, 2017Tutor
Windows7 Can't connect to my ReadyNAS 104
I just update my ReadyNAS104 firmware to 6.6.1, Now I can't access to my NAS from my computer windows7. it was working fine. keep asking me to enter username and password. I enter everything and stil...
mdgm-ntgr
Feb 24, 2017NETGEAR Employee Retired
aalexandrebeta wrote:
The 6.6.1 FW is painfull and the beta release of the 6.7.0 is done and waiting the official FW release!
We've released a second 6.7.0 Beta firmware now and it would be wrong to assume that every possible problem would be a bug that a firmware update would solve.
Superdan186 can you still login to the web admin page?
Which firmware did you update from?
Which services are you running?
Which apps do you have installed?
Superdan186
Feb 28, 2017Tutor
I login using raidar and I don't remember what was the version before 6.6.1. I update from nas auto update as I login it say update available so I did. Service running SMB AFP NFS FTP iTunes ReadyDLNA HTTPS AntiVirus. I don't have any app install I think is useless. I still can't login my own server all my computer mapping drive are disconnected.
