el_patron
May 29, 2019Tutor
x-raid, flex-raid, ... how?
I have a 2-bay pro 2, running with a 1 TB disk on OS6 in X-raid mode. I want to replace the 1TB disk with a 4TB disk, but without redoing the whole setup. I only have and need one drive. There is no ...
Jun 30, 2019Guru - Experienced User
But then comes the part I'm not sure about. Will XRAID then start expansion of the volume to fill the 4TB drive, or can it be done in FlexRAID?
I believe the goal here is to create a second volume on the 4 TB drive. That was why I suggested switching to flexraid before executing any of the ssh commands. Perhaps click on format before creating a new volume on the drive.
el_patron
Jul 01, 2019Tutor
Thanks for all your input... Hmmmhh.... I will reevaluate the effort to do a fresh install of the NAS. In addition to the data there are some services and servers running that need then a new installation:
- bubbleupnp
- minimserver
- nextcloud
Thats the nasty thing...
