psailast
Jun 18, 2020Aspirant
Read Nas 104 supports ReadyDr
Read Nas 104 Firmware 6.10.3 supports ReadyDr As I do not have the Ready Dr Option
psailast
Jun 19, 2020Aspirant
I have Ready Nas 104 I ReadyNas replicate to keep date on another ReadyNas 104 off site as a data recovery plan just in case I lose of the the Ready Nas. Being that Ready Nas replicate would no longer be avaliable after October 2020 what I shall is do to continue to keep a back a clone of Readynas being that my ReadyDr is not supported on my systems
Jun 19, 2020Guru - Experienced User
psailast wrote:
what shall I do to continue to keep a back a clone of Readynas being that my ReadyDr is not supported on my systems
You could switch to rsync-over-ssh, and enable custom snapshots on the destination NAS to give you some rollback/retention.
- psailastJul 02, 2020Aspirant
I am try to set the rsync-over-ssh what should i include under the host the ISP IP address wherr the other NAS is located? I am having the attached error
- StephenBJul 02, 2020Guru - Experienced User
Generally you'd set up DDNS on the remote system, so you can use a hostname that will track the WAN address of the remote router (which generally will change without notice).
Many Netgear routers have a built-in DDNS service you can use (getting a name like psailist.mynetgear.com. NoIP.com has a free DDNS option, along with paid options.
Most routers will support DDNS. If yours doesn't, you can also install software on a PC that connects to the DDNS service, and periodically refreshes the DDNS IP address.
You also will need to forward the port you are using for rsync-over-ssh in the remote router.
If I go for the NoIP.com for the DDNS being that both our routers will support DDNS do I need to install software on a PC that connects to the DDNS service, and periodically refreshes the DDNS IP address?
In order for the Rsync-over-ssh to operate the PC needs to be switched on? Is there any other option to have a replicate of my ReadyNas on the other Readynas which is at a remote site
Thanks
