Stuart3142
Sep 09, 2021Aspirant
Ready Nas 102 no web admin
Hi All, My 102 did an upgrade to 6.10.5 and I lost the admin, blank page, could not establish a connection. Reading the admin site I rolled back to 6.10.4 still no login same error. The NAS still fu...
Sep 09, 2021Guru - Experienced User
You need hotfix 1 with 6.10.5. Is the NAS able to reach the internet?
How did you downgrade?
- Stuart3142Sep 09, 2021Aspirant
I am on 6.10.4 now and I can ping my main name server, so yes I can see the wan/internet.
I down graded using the command line.
How do I get hot fix 1?
- StephenBSep 09, 2021Guru - Experienced User
But the hotfix is specific to 6.10.5
Did you reboot after you downgraded?
Thanks for this, I will give it a go later.
I will upgrade it to 6.10.5 first.
Yes I did reboot.
What does this hot fix fix? Is it just the keys?
