Stuart3142
Sep 09, 2021Aspirant
Ready Nas 102 no web admin
Hi All, My 102 did an upgrade to 6.10.5 and I lost the admin, blank page, could not establish a connection. Reading the admin site I rolled back to 6.10.4 still no login same error. The NAS still fu...
Sep 09, 2021Guru - Experienced User
You need hotfix 1 with 6.10.5. Is the NAS able to reach the internet?
How did you downgrade?
Stuart3142
I am on 6.10.4 now and I can ping my main name server, so yes I can see the wan/internet.
I down graded using the command line.
How do I get hot fix 1?
- StephenBSep 09, 2021Guru - Experienced User
But the hotfix is specific to 6.10.5
Did you reboot after you downgraded?
- Stuart3142Sep 09, 2021Aspirant
Thanks for this, I will give it a go later.
I will upgrade it to 6.10.5 first.
Yes I did reboot.
What does this hot fix fix? Is it just the keys?
It just fixes the login loop that some folks have experienced when trying to access the NAS web ui.
