Stuart3142
Sep 09, 2021Aspirant
Ready Nas 102 no web admin
Hi All, My 102 did an upgrade to 6.10.5 and I lost the admin, blank page, could not establish a connection. Reading the admin site I rolled back to 6.10.4 still no login same error. The NAS still fu...
Stuart3142
I am on 6.10.4 now and I can ping my main name server, so yes I can see the wan/internet.
I down graded using the command line.
How do I get hot fix 1?
Sep 09, 2021Guru - Experienced User
But the hotfix is specific to 6.10.5
Did you reboot after you downgraded?
- Stuart3142Sep 09, 2021Aspirant
Thanks for this, I will give it a go later.
I will upgrade it to 6.10.5 first.
Yes I did reboot.
What does this hot fix fix? Is it just the keys?
- StephenBSep 09, 2021Guru - Experienced User
It just fixes the login loop that some folks have experienced when trying to access the NAS web ui.
Hi StephenB,
This does not work for me, I upgraded to 6.10.5 first then ran the fix, apache2 still will not start and I have the same key error as before!
When applying the fix I get the same message as in the post from kohdee. So this is not failing. Looks like this is not as described a loop problem on my 102.
I can not run any of the cammands from Raidar, it will not take the login and password.
To sum up apache2 will not start due to a pem error, I have no admin web area, also this seems to be linked to the passwd file as raidar rejects all passwords.
What do we do now?
