PMDev
May 10, 2023Aspirant
Ready nas 102 transfer speed
I have a Readynas 102, is seems to be a bit slow, it’s fitted with 2 4tb iron wolf drives and has a 1000mbps connection. I’ve ran a test with nas performance tester and the speeds are Write 37MB / Se...
May 10, 2023Guru - Experienced User
Write 37MB / Sec
Read 21MB /Sec
What firmware are you running?
Is the PC connected using gigabit ethernet?
PMDev
Latest FW, computer has gigabit connection
- StephenBMay 11, 2023Guru - Experienced User
If the data volume is very old, doing a factory default will speed it up.
Also, if ipv6 is enabled, then I suggest disabling it.
- PMDevMay 11, 2023AspirantIt’s about 2 years old. I’ve just disabled ipv6 but it didn’t help☹️
PMDev wrote:
It’s about 2 years old.Still might help (depending on what firmware you were running when the volume was created).
It's been a while since I checked the speed (my RN102 is only used for some testing). But I just took a look. I'm getting 50-60 MB/s with NASTester 1.7, using a 400 MB file size. Disabling strict sync increases the write speed to 70 MB/s, but of course doesn't affect read speeds.
Running warmup... Running a 400MB file write on \\10.0.0.13\Videos 5 times... Iteration 1: 73.67 MB/sec Iteration 2: 68.34 MB/sec Iteration 3: 74.49 MB/sec Iteration 4: 76.29 MB/sec Iteration 5: 66.82 MB/sec ----------------------------- Average (W): 71.92 MB/sec ----------------------------- Running a 400MB file read on \\10.0.0.13\Videos 5 times... Iteration 1: 55.77 MB/sec Iteration 2: 55.46 MB/sec Iteration 3: 56.33 MB/sec Iteration 4: 55.81 MB/sec Iteration 5: 48.16 MB/sec ----------------------------- Average (R): 54.31 MB/sec -----------------------------The NAS is running 6.10.8 firmware, and is using XRAID (two 1 TB Seagate Ironwolf drives).
File size definitely matters in these tests - with small files, the speeds are much slower.
