gvan
Nov 22, 2015Aspirant
Ready NAS 104 Corrupting files while copying. Teracopy confirms it.
I copied almost 3 TB of video files to the readyNAS with no problems. It's set up as JBOD currently. 4TB drive, 2TB drive (unused, I think) and a 1.5 TB drive. These all work fine. I copied them using the backup program from USB and over the network.
If I copy a single file to or from the ReadyNAS to my PC over the network, the file won't play. I popped open Teracopy and sure enough the checksums are different.
I see forum posts of this happening many firmware revisions ago, but nothing recent. Any ideas?
Gvan
That firmware are you running?
- gvanAspirant
Sorry. I forgot to put that. I'm running 6.4.0 which is the latest I can find save the beta.
I did notice something. The size of the data volume (data2 is brand new and empty right now) is off. At one time, I think I had 2 disks in that volume and then started it over with one disk.
Tonight I plan to attempt a backup of a few files from data to data2. if it works, I'll back everything up and start it all over.
