RacingTog
Oct 18, 2021Aspirant
Ready NAS 212 and Acronis Cyber Protect Home Office
Hello Everyone, I am running Windows 10 64bit Firmware: 6.10.5. Hotfix 1 I have a Netgear Ready NAS 212 and want to backup my files from a LaCie RAID USB storage device. I am using Acro...
RacingTog
Oct 20, 2021Aspirant
Hi Stephen,
The disk test has run. I haven't had any reports from it.
Oct 20, 2021Guru - Experienced User
It must have passed then - you would have seen messages if it had failed.
RacingTog wrote:
How do I measure the transfer speed in drag and drop?
You can simply copy a folder, and monitor how long it takes.
RacingTog wrote:
It is only Acronis it won't work with. They seemed to think it was some sort of permissions issue.
If it were permissions, it simply wouldn't have copied files. So I see how it could be permissions.
- RacingTogOct 21, 2021Aspirant
Hi Stephen,
OK, so to update: I got fed up of waiting for Acronis to complete and I instead used GoodSynch to do the backup. This it did in less than 20 hours.
So far we have established:
1) Acronis software works absolutely fine with all backup jobs including backups to all my Netgear NAS units except this particular one.
2) Goodsynch works absolutely fine with this NAS.
We can concude that both Acronis and the Netgear NAS drives are working fine. The outstanding issue is:
"Why won't Acronis work on this particular NAS?" Acronis engineers worked for three weeks on this issue and said it was something to do with the NAS. They suggested it might be a permissions issue.
Where do we go from here please?
many thanks,
I am much obliged,
RacingTog (Matt)
- StephenBOct 21, 2021Guru - Experienced User
In your first post on this, you said "It takes over a week to do a backup to the Netgear NAS." If the backup is running very slowly, then the problem cannot be permissions. A permissions problem would result in the backup failing altogether (either skipping some files, or stopping with an error). My take is that they simply have no idea on what the problem is.
One option is to try creating a new share on the NAS for the backup. Rename the existing share, and create a fresh one that matches the original name. Then run Acronis again, and see if it works normally. If it does, then you can delete the original share when the backup completes.
Thank you for the reply Stephen,
I have set that backup up 6-8 times, usually with a complet re-set of the NAS to factory default before trying a new share and backup. The same thing happens everytime. The backup tells me it will take about 9-12 days. The backup runs for about 5-6 days, then it stops with some sort of error. useually that it couldn't find the destination drive (NAS). Then, I restart it and it runs again for a few days and stops again with the same error. When I check the NAS, there are substantioal backup files created on it. I have never had the patience to let it complete.
- RacingTogNov 08, 2021Aspirant
Just closing this issue now. There was not a solution found. Acronis works perfectly with my other Netgear NAS drives, inc one which is identical in every way, same model, same firmware. But it simply won't work properly with one particular NAS. I have given up and am now using GoodSync software with that NAS and it works fine.
