RacingTog
Oct 18, 2021Aspirant
Ready NAS 212 and Acronis Cyber Protect Home Office
Hello Everyone, I am running Windows 10 64bit Firmware: 6.10.5. Hotfix 1 I have a Netgear Ready NAS 212 and want to backup my files from a LaCie RAID USB storage device. I am using Acro...
RacingTog
Oct 21, 2021Aspirant
Thank you for the reply Stephen,
I have set that backup up 6-8 times, usually with a complet re-set of the NAS to factory default before trying a new share and backup. The same thing happens everytime. The backup tells me it will take about 9-12 days. The backup runs for about 5-6 days, then it stops with some sort of error. useually that it couldn't find the destination drive (NAS). Then, I restart it and it runs again for a few days and stops again with the same error. When I check the NAS, there are substantioal backup files created on it. I have never had the patience to let it complete.
RacingTog
Nov 08, 2021Aspirant
Just closing this issue now. There was not a solution found. Acronis works perfectly with my other Netgear NAS drives, inc one which is identical in every way, same model, same firmware. But it simply won't work properly with one particular NAS. I have given up and am now using GoodSync software with that NAS and it works fine.
