aguden_guden_co
Sep 19, 2022Luminary
Ready NAS 314 - Fine on RAIDar but Can't open in File explorer
I have one ReadyNAS 314 and one 316. Both show up when I run RAIDar but when I click on either of the devices shown on Windows (10) file explorer, I cannot connect to either device. The message I g...
Sep 21, 2022Guru - Experienced User
aguden_guden_co wrote:
It assigned T: to the drive. But again both tries on the other drive failed.
Maybe try rebooting the PC and the NAS next.
aguden_guden_co
Sep 23, 2022Luminary
Both NAS boxes are back fully online now. Ver odd but evidently that program cleans something out of the registry and after a while the network fixes it. It may be one of the bunch of overnigt things that run from the task scheduler. I've spent enough time on it and so have you all. My take away is don't run USB Oblivion unless something really needs fixing (I usually just do it premptively). And if I have to do it just have patience and every thing will be normal in a day or two.
Thanks again for your time and efforts.
