Clammy
Aug 12, 2020Guide
Ready NAS 6 Series power issues
Hi, I have two Ready Nas 6 series devices, the Pro 6000 and a 6310, both long out of warranty. I took them out of storage and put 4tb Drives in both of them but when I try to turn them on, they...
Aug 12, 2020Guru - Experienced User
Clammy wrote:
One of them one of the drives that I have to pull out to get it working is one on a replaced drive sled (the originals were the ones with the paperclip button to release and I had to replace one with a newer slide button release type sled). It doesn't matter which hard drive is in that sled but if that sled is in, it doesn't power on or shuts off after a few seconds. I don't see how the sled makes any difference and when I look in the case, it does seem that the sled still slides the drive in tightly.
Both of these used to have slower 3tb drives in them. Is this a power issue? Are the drives drawing too much power?
This is happening in both NAS? With different disks in different trays?
What happens if you try putting just the one tray in the NAS (leaving the others empty) and then power it up?
Are the symptoms different when you switch that drive to a different tray, and power it up again?
FWIW, this sounds like an issue with the replacement sled.
- ClammyAug 12, 2020Guide
Both NASes won't power on or will shut off after a few seconds with all the drives in. I have to remove 1 or 2 drives for them to turn on. It doesn't matter which drive, I've switched the drives on the sleds around and it didn't matter.
Only one of them has a replacement sled and if that sled was in, it would shut off or not turn on. But even with that one out, I'd have to remove 1 or 2 more drives to get it to turn on.
I have tried to take all drives out and just put 1 in, and it will turn on and stay on. I can't seem to find any sort of common problem. It's sometimes it won't turn on at all even with just 4 drives in, and I have to pop a drive out and put it back in then it'll turn on or unplug the power and try again.
This is really annoying since it's happening on TWO NASes. I'm just glad my primary right now is NOT a netgear.
- StephenBAug 13, 2020Guru - Experienced User
That is a little more clear. So the replacement sled isn't working properly. Is this from a Netgear NAS? Does it have a part number you can share? Maybe also post a photo. There are a few trays out there, and it is possible you have one that wasn't designed for the Pro.
This would be the real problem then? This does sound like the power supplies might have failed - though odd that this would happen to both NAS. Are you certain these were working properly when they were stored?
It might be worth opening the chassis, and check the cabling. There are three molex connectors from the supply that go to the top of the NAS, and it is conceivable that one of them became loose or was damaged in storage. Though normally they are pretty tight.
Since you already have a PSU on order, you can of course confirm by installing the new one.
I get it is annoying, but the build quality of the Pro-6 is actually quite good. Still, components do fail, and you are talking about NAS that are getting pretty old (7-12 years).
Though I agree it is unusual that you'd have two NAS that both have this particular symptom - which is why I am wondering about their history. Were you the original purchaser? How and where were they stored?
- ClammyAug 13, 2020Guide
The sled does not have a part number on it, I don't recall where I got it but I do recall it was a bit difficult to find at the time. It's exactly the same size as the other sleds and when I put a hard drive in there, it sits exactly the same amount out as the other sleds so I'm not sure why the sled would cause a problem. It's only a physical component that holds the drive in place and as far as I can tell, it's identical to my other sleds.
I am the original owner of the pro 6 and the second owner of the older 6310. They were both working before I stored them away. I put 4x 4tb drives into the 6pro and had 6x 3tb drives into the 6310. Both had the raids built and I used them to backup my current active raid device. They were stored in the corner of a closet in a box. I have no concern for the data on there. When I pulled them out last weekend, I replaced the 3tb drives in teh 6310 with 6x 4tb drives and the pro 6 wouldn't turn on at all. The 6310 did turn on at first but eventually shut off on it's own then the problems began. The pro 6, I thought had a bad psu so I ordered one, then discovered that if I popped the drives out it would boot. I forgot to mention the pro 6 doesn't even have all 6 drives, just 4x.
I did open the both chasis to check for cabling issues, all cables seem to be secure.
To be honest, I don't care so much about the 6310, but I don't think the pro 6 should have out lived it's usefulness less than 3 years after warranty. It's also strange that both seem to have nearly identical problems. There's quite a few threads about PSUs going even while under warranty and they both of have identifical PSUs. However, they were working before being stored away so it's not even like the PSUs are dying under use or load.
I do hope it is JUST the PSU but that's still crap for quality. I'm still waiting on it to arrive. Otherwise, I hope it's just some configuration issue or something. I tried a factory reset on the 6310 with one drive in there, the problems persisted once I put the other drives back in.
