Clammy
Aug 12, 2020Guide
Ready NAS 6 Series power issues
Hi, I have two Ready Nas 6 series devices, the Pro 6000 and a 6310, both long out of warranty. I took them out of storage and put 4tb Drives in both of them but when I try to turn them on, they...
Clammy
Aug 12, 2020Guide
Both NASes won't power on or will shut off after a few seconds with all the drives in. I have to remove 1 or 2 drives for them to turn on. It doesn't matter which drive, I've switched the drives on the sleds around and it didn't matter.
Only one of them has a replacement sled and if that sled was in, it would shut off or not turn on. But even with that one out, I'd have to remove 1 or 2 more drives to get it to turn on.
I have tried to take all drives out and just put 1 in, and it will turn on and stay on. I can't seem to find any sort of common problem. It's sometimes it won't turn on at all even with just 4 drives in, and I have to pop a drive out and put it back in then it'll turn on or unplug the power and try again.
This is really annoying since it's happening on TWO NASes. I'm just glad my primary right now is NOT a netgear.
Aug 13, 2020Guru - Experienced User
That is a little more clear. So the replacement sled isn't working properly. Is this from a Netgear NAS? Does it have a part number you can share? Maybe also post a photo. There are a few trays out there, and it is possible you have one that wasn't designed for the Pro.
This would be the real problem then? This does sound like the power supplies might have failed - though odd that this would happen to both NAS. Are you certain these were working properly when they were stored?
It might be worth opening the chassis, and check the cabling. There are three molex connectors from the supply that go to the top of the NAS, and it is conceivable that one of them became loose or was damaged in storage. Though normally they are pretty tight.
Since you already have a PSU on order, you can of course confirm by installing the new one.
I get it is annoying, but the build quality of the Pro-6 is actually quite good. Still, components do fail, and you are talking about NAS that are getting pretty old (7-12 years).
Though I agree it is unusual that you'd have two NAS that both have this particular symptom - which is why I am wondering about their history. Were you the original purchaser? How and where were they stored?
- ClammyAug 13, 2020Guide
The sled does not have a part number on it, I don't recall where I got it but I do recall it was a bit difficult to find at the time. It's exactly the same size as the other sleds and when I put a hard drive in there, it sits exactly the same amount out as the other sleds so I'm not sure why the sled would cause a problem. It's only a physical component that holds the drive in place and as far as I can tell, it's identical to my other sleds.
I am the original owner of the pro 6 and the second owner of the older 6310. They were both working before I stored them away. I put 4x 4tb drives into the 6pro and had 6x 3tb drives into the 6310. Both had the raids built and I used them to backup my current active raid device. They were stored in the corner of a closet in a box. I have no concern for the data on there. When I pulled them out last weekend, I replaced the 3tb drives in teh 6310 with 6x 4tb drives and the pro 6 wouldn't turn on at all. The 6310 did turn on at first but eventually shut off on it's own then the problems began. The pro 6, I thought had a bad psu so I ordered one, then discovered that if I popped the drives out it would boot. I forgot to mention the pro 6 doesn't even have all 6 drives, just 4x.
I did open the both chasis to check for cabling issues, all cables seem to be secure.
To be honest, I don't care so much about the 6310, but I don't think the pro 6 should have out lived it's usefulness less than 3 years after warranty. It's also strange that both seem to have nearly identical problems. There's quite a few threads about PSUs going even while under warranty and they both of have identifical PSUs. However, they were working before being stored away so it's not even like the PSUs are dying under use or load.
I do hope it is JUST the PSU but that's still crap for quality. I'm still waiting on it to arrive. Otherwise, I hope it's just some configuration issue or something. I tried a factory reset on the 6310 with one drive in there, the problems persisted once I put the other drives back in.
- SandsharkAug 13, 2020Sensei
If the replacement caddy is from a NAS that was designed for OS6 (includes the toolless plastic insert), then it will not properly seat in a legacy NAS. But I can't even got one of those fully into a Pro6, so I don't think that's your issue. Legacy caddies with the square button are compatible with legacy NAS all the way back to the NV and there is no problem mixing the two button types. So that makes me wonder what could be wrong with your specific caddy.
Your main issue does sound like power, so the replacement supply is your best next step unless you have a spare ATX12V supply you can try mounted externally.
If it was possible the storage temperature got close to or below freezing, that can be bad on solder joints, especially several cycles between very cold and hot. But from your description, I don't think that's the case. I don't know of any other likely failure mode due to storage. But there have been reports that changing the button cell has helped with boot issues (though I can't explain why), so that could be worth a try. Maybe even just remove it.
The closet it was stored in never gets below freezing because my rack is in there. I actually have a vent and fan so it doesn't get much over 85 (or ambient house temperature above that) because it gets warm.
I'm sorry, I don't understand what you mean about the button cell?
