WellingtonBDS
Mar 06, 2023Aspirant
Ready NAS duo V2 does not access frontview
Hello! I have a ReadyNAS Duo V2 and I haven't entered the setup for a long time. The system is Windows 10 and the problem happens in all browsers It is working and I have access to the files. Now...
Mar 06, 2023Guru - Experienced User
WellingtonBDS wrote:I have a ReadyNAS Duo V2
Your screenshot appears to be from the original Duo (called a v1 here).
The original Duo (v1)
- runs 4.1.x firmware
- says "ReadyNAS Duo" on the front panel.
The Duo v2
- runs 5.3.x firmware
- says "ReadyNAS Duo v2" on the front panel.
Ignore other labels, they are more confusing than helpful.
An error occurred during a connection to 192.168.1.208. The remote system uses an unsupported version of the security protocol.
Error code: SSL_ERROR_UNSUPPORTED_VERSION
This site may not support the TLS 1.2 protocol, the minimum version supported by Firefox.
See this thread:
If you skip to the end, you'll find a setting which allows FireFox to connect. One downside of doing that is that it enable TLS 1.0 generally (for all websites). If you run Windows, then Internet Explorer or Edge in IE mode will also work.
Editing virtual.conf (once you regain temporary access) is another option, instructions for that in the beginning of the thread.
The Duo v2 add-on won't work in your case (since you actually have a v1).
Only the IP number
NASnumberIP/shares
incomplete sharing, only access to password change
That only shows you something if you have configured one or more shares to allow HTTP access.
WellingtonBDS
Mar 07, 2023Aspirant
Thank you for the informations
I read your post (2022-03-05 03:50 AM) detailing the procedure, I copied the script in notepad++ and saved it in a shared folder on the NAS, I downloaded SSL EnableRootSSH_1.0.bin, but I don't know how to use it to access the root from the NAS
- WellingtonBDSMar 07, 2023Aspirant
I installed FireFox 94.0.2 and now access the NAS frontview
Hostname: nas-6B-AC-B6
Model: ReadyNAS Duo [X-RAID]
Serial: 24M4147V00C80
Firmware: RAIDiator 4.1.16 [1.00a043]
Memory: 256 MB [2.5-3-3-7]
IPv4 address:: 192.168.1.208
Volume C: Online, X-RAID, 2 disks, 79% of 1846 GB used - StephenBMar 07, 2023Guru - Experienced User
You install it as an add-on in Frontview.
Then you can access the NAS by entering
ssh root@nas-ip-addressfrom the windows search bar.
That will open a command box. You will need to allow the connection the first time. Then enter the NAS admin IP password at the prompt.
Wouldn't it be for local access, where I put the .bin file in the NAS shared folder on my PC?
