WellingtonBDS
Mar 06, 2023Aspirant
Ready NAS duo V2 does not access frontview
Hello! I have a ReadyNAS Duo V2 and I haven't entered the setup for a long time. The system is Windows 10 and the problem happens in all browsers It is working and I have access to the files. Now...
WellingtonBDS
Mar 07, 2023Aspirant
Thank you for the informations
I read your post (2022-03-05 03:50 AM) detailing the procedure, I copied the script in notepad++ and saved it in a shared folder on the NAS, I downloaded SSL EnableRootSSH_1.0.bin, but I don't know how to use it to access the root from the NAS
Mar 07, 2023Guru - Experienced User
You install it as an add-on in Frontview.
Then you can access the NAS by entering
ssh root@nas-ip-address
from the windows search bar.
That will open a command box. You will need to allow the connection the first time. Then enter the NAS admin IP password at the prompt.
