WellingtonBDS
Mar 06, 2023Aspirant
Ready NAS duo V2 does not access frontview
Hello! I have a ReadyNAS Duo V2 and I haven't entered the setup for a long time. The system is Windows 10 and the problem happens in all browsers It is working and I have access to the files. Now...
Mar 07, 2023Guru - Experienced User
You started by clicking on "system", and you should have clicked on "status".
Though it's possible that 4.2.x systems have a slightly different organization. I'll fire up my old NV+ and take a look.
Yes, it is a bit different. Don't attempt to register or check for updates on the remote tab, as that will give you the "error connecting to remote server" error. If you do get it, then just click ok.
Select
- System
- Update
From the left pane.
Then select Local at the top.
First you "Choose File", and select the .bin file
Next you click on "Upload and verify image".
- WellingtonBDSMar 07, 2023Aspirant
The way you put it, I managed to update with the .bin file
But in the windows search bar typing ssh root@NASipAddress opens the black prompt screen and closes without any action. So I opened the Promp as administrator and tried. It gave
C:\WINDOWS\system32>ssh root@192.168.1.208
ssh: connect to host port 22: Connection refusedC:\WINDOWS\system32>
- StephenBMar 07, 2023Guru - Experienced User
Did you perhaps install it twice? It won't show up in the installed add-on list, and if you do install it a second time I believe it will actually un-install itself.
Out of doubt, I installed it once again with success.
On NAS reboot confirms installation
But I still don't have access to the root of the server
ssh: connect to host port 22: Connection refused - StephenBMar 08, 2023Guru - Experienced User
ssh: connect to host port 22: Connection refusedAre you perhaps using the default admin password (netgear1)?
Also, I am wondering if you have internet security software running on the PC. If you do, try disabling it.
- WellingtonBDSMar 08, 2023Aspirant
I'm not using the default password
But since I can't log in, it doesn't ask for a passwordI created new rule in Windows Firewall and
I released port 22 for all protocols
I enabled the ip 192.168.1.208Disabled Avira Antivirus scan and turned off Malware Bites
second try: i disabled the firewall too
I still have access denied on port 22C:\WINDOWS\system32>ssh root@192.168.1.208
But since I can't log in, it doesn't ask for a passwordI asked because some features are intentionally disabled if you are using the default password.
ssh: connect to host port 22: Connection refusedMaybe try rebooting the NAS, and see if that helps.
But this might be Avira - not sure what package you have, but they offer internet security software, and not just AntiVirus. Was it completely disabled? I don't think malwarebytes will get in the way - I have had the "premium trial" on some of my PCs, and was able to use ssh on them.
Most of these packages have logs, so you could also look at them for any signs that they are blocking the port.
- WellingtonBDSMar 13, 2023Aspirant
Hello Stephen!
I did everything in my power and I couldn't get to the root of the NAS to update
I'm a photographer and I use Duo to store my work (I'm the type that doesn't store it in the cloud), just because of the security of XRaid mode, I don't connect to it via the internet, I use it only as local storage.
So I'll settle for accessing Frontview via old Firefox (I'll save the installation for future needs)
If you have a suggestion for another type of safe file storage, you can suggest
Thanks for your prompt attention. - StephenBMar 13, 2023Guru - Experienced User
WellingtonBDS wrote:If you have a suggestion for another type of safe file storage, you can suggest
You could purchase a new NAS (Netgear stopped selling your model back in 2011).
You won't find a new ReadyNAS though, so you'd need to switch to a different vendor. Synology, or perhaps Asustor???
Hello!
It seems to me that this Synology DS418 is a good option at an affordable cost
WellingtonBDS wrote:It seems to me that this Synology DS418 is a good option at an affordable cost
https://www.synology.com/en-br/products/DS418
I've never owned a synology, so can't really give a personal recommendation.
But this would be reasonable. You could also look at 2-bay models (getting larger disks to compensate).
