audetto
Aug 19, 2011Aspirant
Ready NAS hanging
Hi, I've got a ReadyNAS NV+ and in the last couple of weeks bad things have started happening 1) worst: the Ready NAS disappears from network and can be powered off at all (I had to remove the p...
PapaBear1
Aug 19, 2011Apprentice
1. You should not sent the logs to Negear unless a tech or Jedi asks from them. They are generally sent directly to an individual.
2. It is not a good idea to swap drives around in the NAS, especially if one or more drives is throwing errors. That is a good way to lose the entire array.
3. Generally, when you first begin having problems, the best first thing to do is to create/update your current and complete backup. With a complete backup, if you lose the array, you still have a way to recover your data. If you do not have a current and complete backup, create one now before you do lose the array. (I lost one Wednesday because two drives had a problem in a 3 drive array. However, since it was the second backup of critical/important data and the original and backup are intact, my data is secure.)
4. What are the make and model(s) of the drives?
