Beer4Cheer
Jul 03, 2016Aspirant
Ready NAS RN10400 will not power up **DEAD**
My Rady NAS died recntly. I was away from home when it happened. All of a sudden I just could not access it remotely. When I got home, there were no lights on it, and none of the drives or fan was...
Jul 04, 2016Guru - Experienced User
If you are covered by the hardware warranty (3 years for the original purchaser) then you should contact support.
DaneA
Jul 04, 2016NETGEAR Employee Retired
Hi Beer4Cheer,
Welcome to the community! :)
Let us isolate the problem. Kindly answer the questions below:
a. Have you tried to plug your NAS to other AC outlet(s) then check if it will boot up just fine?
b. Pull-out the drives from your NAS. Be sure to label the drives from which bay you have pulled it out. Then, try to turn on the NAS without drives. Did your NAS turn on without any drives inside?
c. Is there a burning smell coming from your NAS?
d. Was there a power outage that happened where the NAS is deployed?
e. Do you have a backup of your data stored in your NAS to another external drive or to another NAS?
If ever that your NAS won't really boot up, I advise you to open an online case with NETGEAR Support at anytime. State the condition of your NAS for further assistance. If ever the NAS chassis is found faulty, then please be ready to submit a soft copy of the Proof of Purchase or Sales Invoice of your device for warranty verification via the online case you have opened. If the hardware warranty is still valid, then an online replacement will follow.
DaneA
NETGEAR Community Team
- Beer4CheerJul 04, 2016Aspirant
Hello,
This NAS was registered when I purchased it on 04/09/14. I have already contacted Customer Support and received Case #27094766.
As for your questions:
a. Have you tried to plug your NAS to other AC outlet(s) then check if it will boot up just fine? YES
b. Pull-out the drives from your NAS. Be sure to label the drives from which bay you have pulled it out. Then, try to turn on the NAS without drives. Did your NAS turn on without any drives inside? YES I removed the drives, and NO it did not power up. Same Symptom.
c. Is there a burning smell coming from your NAS? NO
d. Was there a power outage that happened where the NAS is deployed? NO, Not that I am aware of.
e. Do you have a backup of your data stored in your NAS to another external drive or to another NAS? NO, not all of it.
Thank you for your quick rsponse!
- DaneAJul 07, 2016NETGEAR Employee Retired
Hi Beer4Cheer,
Just want to follow-up on this. Any updates on the online case you have opened with NETGEAR Support?
DaneA
- Beer4CheerJul 11, 2016Aspirant
No, I have not heard anything from them. I will likely call them this afternoon if I don't get a response this morning. I really do not think it is the "brick" power suppy as I am getting 12VDC off of two of the pins. I am thinking it is the main unit. I should just be able to put the old drives into a new unti, and have everything come right back up, correct?
