mrstraton1969
Jan 18, 2021Follower
Ready NAS RN21400
hi
I have a Ready Nas and I have had it connected to Rready cloud for a while, I replaced all the disks and when the unit came back on line it shows everything it should do when you log into it, however it's showing as off line on readycloud, I removed it from ready cloud and when i try and it back to readycloud it says it already added? Has anyone any ideas where I need to go?
Thanks
Paul
- JohnCM_SNETGEAR Employee Retired
Hi mrstraton1969,
Welcome to the Community!
May I know the current firmware of your RN214?
Under the Cloud tab of the NAS' local admin page, you can check the status of the Internet and Service. Both of them should have a green check for the ReadyCLOUD to work. If one of them does not have it, you can try assigning a static DNS address on the NAS and see if that helps in resolving the issue.
Hi mrstraton1969,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
